Re: Engine Knock
Posted by BillyinStoughton on October 20, 2005 at 10:18:05 from (208.50.85.56):
In Reply to: engine knock posted by fenton on October 20, 2005 at 09:48:48:
It could be a number of things...something as simple as timing for example. Check your ICH manual and set timing at factory recommendation.
Also check for correct spark on all cylinders.
Another aid in trouble shooting may be "what type of knock is it?". Is it a heavy single knock (maybe bottom end related), or a light double knock (indicating a wrist pin)? All these things may help you get to the root of your problem.
Remember, any moving part in your engine can be a culprit in a mechanical noise...so don"t overlook for valve train either!
Hope this helps!
Post a Followup
