300 U Clutch?
Posted by rmz290 on October 20, 2005 at 11:53:59 from (71.192.194.153):
My 300 U will give me a hard time shifting every once in a while. To switch gears I have to pull th TA. It seems like the clutch pedal does not have enough travel. For example when it's going down a small hill and you go to shift to reverse. It seems like everything is locked up until you pull the TA, which then frees it up.
Is this an adjustment issue with the main clutch? I have not tried adjusting anything yet.
Thanks!
Post a Followup
