This sounds crazy, but it happens on my 300U
Posted by Joe Kimbriel on October 20, 2005 at 11:59:16 from (136.200.52.33):
It is hard to shift out of gear when there is a load on the tractor. If I drive the tractor without scraping or loading or putting any external force on the tractor, and use what little brakes I have to stop, the clutch releases and it shifts fine. If I have scraped or I am pushing dirt and shove the clutch in the tractor stops fine but it is hard to get the thing out of gear. Once it is out of gear it is real easy to put in another gear and go. What’s the deal? I know that I need to adjust the TA, but right now the clutch lever does not even attempt to move the TA lever and the planetary gears should not be in the picture. Does the TA clutch need to be released every time the clutch is depressed?
Thanks,
Post a Followup
