Farmall A Rear Rims
Posted by Doug Wilkins on October 20, 2005 at 17:45:26 from (216.25.190.52):
Just curious if Farmall A and Farmall BN rear rims and tires are interchangeable or if they have a different bolt pattern? Im assuming they are the same. Thanks guys
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
