Re: Farmall A Rear Rims
Posted by Jim Becker on October 20, 2005 at 18:58:06 from (71.96.8.127):
In Reply to: Farmall A Rear Rims posted by Doug Wilkins on October 20, 2005 at 17:45:26:
If you are talking about the rims (not the wheel centers), they are identical, or at least they can be. There were options for different tire sizes which required different width rims.
The wheel centers on each side of a BN would be identical to each other and match one side or the other of an A, which side depending on whether the BN had the heavy wheel option or not.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
