Farmall Tractors Discussion Board
Re: Re: More power for H
Posted by IHank on December 27, 1999 at 21:19:37 from (167.142.16.135):
In Reply to: Re: More power for H posted by HR on December 27, 1999 at 11:26:59:
Excellent recommendation by HR! Shame on me for not telling it earlier...
Once you got the basics done, couple of oil & filter changes, stable cooling system temperature and thermostat, valve lash adjusted, and especially the old gummed up and wore out governor and spark advance mechanisms back to specs- then your local dyno man, or rich kid with a dyno neighbor, will quickly dial in the wide open throttle & full load spark timing and carburetor main mixture screw adjustments. Keep in mind the tuning tricks for pulling might be all wrong for day to day usage of that H. Good luck! IHank
Post A Followup
: Re: Re: Re: More power for H
