Re: CHEAP GAS!
Posted by Janicholson on October 21, 2005 at 09:54:21 from (199.17.6.175):
In Reply to: Re: CHEAP GAS! posted by Allan in NE on October 21, 2005 at 09:35:22:
Unless your M has an actual compression pressure over 150 PSI (It could if it is modified---LP head, firedome, shaved head), in other words, a race tractor, it wont need more octane. the other posts are correct it is not going to do the intended job. It will smoke more and carbon up the system. If the chambers are deposit filled from years of operation on leaded fuel, it could have glowing deposits causing detonation/ pre ignition. THis usually is indicated by a drastic tendency to run onn when shut off.
Make sure it is in time and the compression pressure (with an accurate compression tester) is normal for a SM ) is between 95 and 120psi If I remember correctly.
JimN
Post a Followup
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
