Re: Pulling Question: S M v. SMTA Pulling Power
Posted by supermpuller on October 21, 2005 at 16:40:34 from (64.184.7.139):
In Reply to: Re: Pulling Question: S M v. SMTA Pulling Power posted by RustyFarmall on October 21, 2005 at 14:16:55:
Most pulls won't let you use TA ,JD guys don't like them, and if they make you use low gear TA isn't going to help much, the SM will be lighter and shorter, I've seen both tractors do well in pulls, when over 6500lbs the SMTA will do better with TA on low side, if both motors are running same hp its a toss-up.The cheapest IH to pull with is a 460 you can run 4500 to 8000lbs and with a 301 motor you'll give other tractors fits.
Post a Followup
