Re: how much will she lift? 45 farmall h
Posted by gene bender on October 22, 2005 at 06:43:51 from (66.43.221.118):
In Reply to: how much will she lift? 45 farmall h posted by lekander883 on October 22, 2005 at 05:28:59:
Depends on what dia the cycls are and how much psi your pump has. Will probably lift more that you need jsut remember when load is up over 4ft or so you are taking wt off rear and upsetting tractor can happen easier. Remember it was not built for round bales way up in the air just raise high enough to clear the ground. Tractors are upsetting every day or so because someone raises way up in air and goes down road hits bump or something and presto upsets. GO SLOW.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
