Re: Farmall 300 wheel ballast
Posted by Hugh MacKay on October 22, 2005 at 07:29:05 from (209.226.247.72):
In Reply to: Farmall 300 wheel ballast posted by redin on October 21, 2005 at 19:36:38:
redin: Not quite sure I agree with some of these guys. Some of the hardest pulls I've ever done with a tractor has been in the woodlot harvesting wood. I've seen my old 300 with 5 ton behind it on many ocasions. Secondly woodlots tend not to be smooth, having hummocks, cradle hills over tree roots. You start draging whole trees over that terrain, it will make tractor pulling look like hauling feathers. That calcium chlorides does two things for you, gives you traction and it gives you lower center of graviety ballast. That lower center of graviety ballast is very important when one wheel goes over one of those 15" high cradle hills.
There may be nothing wrong with your tubes, first I'd try installing new screw in portion of the valve stems and then pump the tires. There is nothing wrong with calcium chloride, so long as you don't have leaks. It also takes a lot of cast iron weights to replace that chloride and they still don't give that low center of graviety.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
