Re: H Gen
Posted by riverbend on October 22, 2005 at 20:14:06 from (208.160.33.6):
In Reply to: H Gen posted by HARMER #1 on October 22, 2005 at 18:14:06:
You might be bumping up against the 3 position / 4 position switch, cut out vs regulator systems.
Old Hs had a cut out where you had to select (4 position sw )how much charge you wanted. Those cut outs have been mostly up dated to voltage regulators. Using a voltage regulator and a 4 position switch can give you some control over the charging rate, but I not sure what it gains you.
I run mine on Lo, and it seems to work fine without running the battery dry. Look for Bob M to chime in - he will be able to explain it.
Greg
Post a Followup
