Re: H Gen
Posted by John T on October 22, 2005 at 20:53:04 from (66.244.90.98):
In Reply to: Re: H Gen posted by riverbend on October 22, 2005 at 20:14:06:
When you replace the old cutout relay and light switch controller with a full fledged Voltage Regulator, you no longer wire the Gens Field post to the light switch, ONLY to the new Voltage Regulator's Field terminal. Then it NOT the light switch regulates the net effective Field current and resultant electromagnetic field strength. When doing so I set any third brush generators to the Max charge position.
The full fledged 3 or 4 terminal Voltage Regulator also has its own internal cutout relay so the old 2 wire device is also no longer used.
The generators Field post requires a ground to conduct current, so its just a matter if one uses the older technology only 2 position (dead ground or resistive ground) light switch or a modern voltage regulator which better regulates the field current and resultant electromagnetic field strenght and charge rate. The VR just regulates better and more precise relative to the condition of the battery so the operator doesnt have to choose high or low charge, its done automatically.
Hope this helps explain the difference.
Best wishes n God Bless
John T, retired electrical engineer
Post a Followup
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
