Re: Dumb C timing question-Sorry
Posted by El Toro on October 23, 2005 at 17:01:24 from (205.188.117.73):
In Reply to: Dumb C timing question-Sorry posted by Dave BN on October 23, 2005 at 13:22:06:
It probably would be easier to do as old has suggested. Remove No1 plug and bring the piston
up on the compression stroke to TDC. Your timing mark on the flywheel should be aligned with the pointer when piston is at TDC. Then pull distributor and set at No1. Then put No1 plug in the cap and reconnect the rest 3-4-2 . I think it was timed on No4 piston and you can leave it there. Hal
Post a Followup
