Re: 6V to 12V
Posted by Bob M on October 24, 2005 at 08:49:13 from (151.190.254.106):
In Reply to: 6V to 12V posted by fluggie in IA on October 24, 2005 at 07:57:55:
A standard 12 volt alternator is easily converted to 6 volts simply by swapping in the appropriate voltage regulator. The reworked alternator will still be negative ground.
6 volt POSITIVE ground alterators indeed exist. They're essentially again a standard 12 volt alternator refitted with appropriately grounded output diodes and 6 volt regulator.
However relative to their 12 volt bretheren, 6 volt alternators and parts to convert 12 volt to 6 volt are rather spendy!
Punch below for more info...
Post a Followup
