Re: 6V to 12V
Posted by IaGary on October 25, 2005 at 04:25:03 from (207.32.0.5):
In Reply to: 6V to 12V posted by fluggie in IA on October 24, 2005 at 07:57:55:
I have 6 volt alt on 300row crop with 8 volt battery. Works great because most 6 volt alts.will put out 8 volts and you can use it with 6 volt lights without damage. The extra 2 volts are just enough to spin starter faster.
Post a Followup
