Re: Wits End - Leaking Oil
Posted by Gene Brooks on October 25, 2005 at 16:54:47 from (64.12.117.13):
In Reply to: Re: Wits End - Leaking Oil posted by Farmall Frank on October 25, 2005 at 15:09:26:
I use a carb. cleaner on the metal to remove oil and grease so that the permatex will seal to the metal on both sides an oil film on the metal will break up any adhesive before it has a chance to sealto the metal ;it works for me !!can't hurt to try it Good luck Gene
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
