Re: Wits End - Leaking Oil
Posted by Farmall Frank on October 25, 2005 at 17:21:41 from (69.76.151.187):
In Reply to: Re: Wits End - Leaking Oil posted by Dave BN on October 25, 2005 at 17:11:38:
I will check the surface for flatness and leftover stuff. I tried before but will be more sure this time.
The crankcase breather, I assume, provides the venting. When I remove the access plate and breather Thursday, I will check the filter that is supposed to be in there according to the parts manual. However, I notice when the engine is pulling very hard and the exhaust starts to smoking, the breather is also pumping a lot of smoke towards the ground. Maybe it is still pugged up, or maybe I have too much blowby. I'm not sure that much blowby is OK.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
