Re: Wits End - Leaking Oil
Posted by Janicholson on October 25, 2005 at 17:32:43 from (66.173.50.109):
In Reply to: Wits End - Leaking Oil posted by Farmall Frank on October 25, 2005 at 15:07:23:
If the pan is leaking, and the tracer indicates that to be the case, ( I'd clean it off and run it again with me watching, and sombody else starting it), the next step is to remove the pan without disturbing the gasket. Keep the bolts organized to assure that you know which holes they came out of. Look at the gasket and see if there is clearly places it was not pressed into the block, and where it is smudged with oil flow. Take a bolt (from the area of the leak) and try it in its hole. If it tightens up before the bolt head gets very close to the block, there may be either long bolts, or obstructed threads. I've seen both happen. Run a bottoming tap into the holes to be sure they are clean, and use different bolts if they seem too long, as above. Place a very flat surface (piece of glass) on the pan mating surface to check flatness by observation. careful straightening can rescue the pan if bent. Installation: Install the pan loosely with no bolts more than finger tight. then tighten them all evenly untill the gasket toughees and all are equal. Then turn them in 1/4 turn each untill they start to pinch the gasket. then use a torque wrench to tighten each to a portion of the final torque until they are all correct. The pan gasket should bulge just a bit in the crack when the bolts are fully tightened. I don't know the spec. , but it should be in the manual. This may seem excessive, however doing it for the fifth time is worse. JimN
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
