Re: Distributor for a 49 farmall
Posted by El Toro on October 25, 2005 at 18:50:42 from (205.188.117.73):
In Reply to: Re: Distributor for a 49 farmall posted by Flatland Farmall on October 25, 2005 at 18:21:22:
You need to check for battery voltage at your ignition switch. It is fed from one of the terminals on the starter solenoid. If you have
voltage to the switch, check the wire on the output side to your coil. If no voltage to your
coil your switch or wire is the problem. Could be a broken wire or a defective switch or corrosion. Hal
Post a Followup
