Re: Wits End - Leaking Oil
Posted by Hugh MacKay on October 26, 2005 at 00:22:25 from (216.208.58.116):
In Reply to: Re: Wits End - Leaking Oil posted by Michael Soldan on October 25, 2005 at 17:41:07:
Mike: I suppose after 50 years a Farmall oil pan could have a pinhole leak. For the big 3 automakers it has been quite common occurence in vehicles even after 5 years, and that is only in the past 25 years. The first time I heard of it, I said,"Riduclous, an oil pan couldn't rust." however they do. But I'll bet no pre 1960 oil pans have rusted pin holes. I have a story also. My 6.2 Chevy diesel had an oil leak. I really hadn't examined it closely. One day I was changing oil, and had reached the point of 4L of new oil back in crankcase. Went back under truck just to double check I had thightened filter and plug. While under truck I took a closer look at pan. My leaked oil was only on flat surface on bottom of oil pan. Clearly it was not a crank seal as I had been expecting to find. I got some rags and cleaner, soon found 3 pin hole leaks. Pan seemed very solid even close to pin holes. Sat.pm and I thought where could I ever get this repaired quickly. I decided NO way. Looked around my shop to see what products I might have for a sealer as a temporary fix. Gasket maker or black was all I could find. Back under truck sanded surface and cleaned it a bit. These pin holes were very slow, similar to blood if you picked your finger with needle. I marked exact location of pin holes, removed oil and cleaned throughly. With tip of finger I forced gasket maker into pin holes. After drying some I applied more on surface, actually did about 3 coats building a patch over entire area of the 3 pin holes. Refilled engine with oil, it didn't leak. About 7 years and 150,000 miles later it still didn't leak. In fact I sold the truck for parts in 2001 as frame was rusted and broken. The buyer put engine in a 4x4 truck he only uses for snow plowing. He gave me good money for that truck, mainly because engine sounded good and had no leaks. I did tell him about the oil pan. His reaction, "If it held for 7 years and 150,000 miles on a diesel, probably wasn't going to fail soon. Since that time I've always taken a second look at quick easy fixes. Believe me it can save a lot of dollars.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
