Re: Wits End - Leaking Oil
Posted by rumplestiltskin on October 26, 2005 at 09:51:04 from (65.216.75.240):
In Reply to: Re: Wits End - Leaking Oil posted by scott#2 on October 25, 2005 at 17:27:19:
I would add just one thing to Scott #2"s suggestion.
When you Permatex the gasket to the pan, squish the gasket down into place and let the Permatex set up overnight. This makes it easier to reinstall the pan, and almost eliminates the chance the gasket can shift or pop out.
Mark W.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
