Re: Farmall A Lights
Posted by MACE on October 27, 2005 at 04:02:59 from (66.83.16.196):
In Reply to: Re: Farmall A Lights posted by blocks on October 26, 2005 at 18:38:25:
I don"t have much experience with Farmalls, as this is my first restoration project and first tractor. So as long as I leave the switch in the low or high charge position when the tractor is not running, will this keep the battery from draining down? How does that work? What removes power from the field of the generator when the tractor is not running?
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
