Re: Wits End - Leaking Oil
Posted by Rev. on October 27, 2005 at 12:31:48 from (67.109.213.210):
In Reply to: Wits End - Leaking Oil posted by Farmall Frank on October 25, 2005 at 15:07:23:
Frank,
If you are working on an H there is another gasket under a plate that is at the rear of the motor. This plate is removeable and allows access to the crank bolts. This might be where you are leaking. Hope this helps.
Rev.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
