stuck pistons on sw4
Posted by jcarter on October 27, 2005 at 18:47:30 from (142.161.204.235):
All 4 pistons are stuck.1&4 are 2/3 up and 2&3 are about 1/4 way up.The position of 2&3 won't let you get a socket on the top rod bolt to get the cap off---up in side of block against horizontal rib. A flat wrench gets between the ribs on the cap, and I can't get any room to turn it.1 & 4 I got the caps off,1 pushes up with a wood block and jack on the floor till the end of the rod jams between the block and crank,about 3/8 inch off movement.4 is the same except it pushed the sleeve out of the block, till the rod got stuck.How do I get these center 2 rods unbolted to get these pistons removed? They have been soaking in deisel first, but now dextron for the last week.Thanks for any help.
Post a Followup
