Re: stuck pistons on sw4
Posted by old on October 27, 2005 at 19:29:14 from (207.69.138.141):
In Reply to: stuck pistons on sw4 posted by jcarter on October 27, 2005 at 18:47:30:
Just a guess/idea. You might, if the engine is out, pull all the main bearings loose and that might let the crank drop down some so you can get to the bolts. You also might topp off each cylinder with turpentine and see if that helps. By the way I do mean turpentine not paint thinner.
Post a Followup
