Re: Super A hydraulic pump
Posted by CNKS on October 27, 2005 at 20:02:22 from (204.249.178.138):
In Reply to: Super A hydraulic pump posted by JRV on October 27, 2005 at 18:46:40:
Some kits have parts for more than one model of pump, although the Pesco and Thompson kits will be different. If the replacement parts fit, ignore the washer if it wasn't in the pump. I have repaired the one on my C, yours is similar, the parts book does not show a diagram. The leak is caused by the front seal or o-ring, the other parts in the kit have no effect on the leak, but replace them anyway. If the shaft is severely grooved you need a speedy sleeve, if the groove was caused by an o-ring as opposed to a regular seal, you have to enlarge the shaft hole to accept the speedy sleeve.
Post a Followup
