Re: Farmall H vs M
Posted by farmallhal on October 28, 2005 at 11:56:38 from (64.24.35.17):
In Reply to: Farmall H vs M posted by Matt Frye on October 26, 2005 at 21:04:13:
Matt, in the front picture (PA260082) you posted below do you see the two approx. 1" holes just below the first wide bar from the top in the grille? Those holes are below the first wide bar on a M and above the first wide bar on a H. The tractor you posted is clearly a M. Hope this helps. Hal
Post a Followup
