Re: I know its not an IH tractor but..
Posted by Dellbertt on October 29, 2005 at 10:59:16 from (204.39.210.66):
In Reply to: I know its not an IH tractor but.. posted by Karl Hamson on October 29, 2005 at 10:30:57:
Theres one mixture adjustment screw on the front of the carb. Mine keeps vibrating rich. The spring gets weak. Let the engine warm up good. Take the screw out and put some non-hardening Permatex on the screw and reinstall. Start the engine and adjust that screw to max rpm and then go in 1/8 turn. Turn the engine off and let the Permatex dry. Should help.
Post a Followup
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
