Re: I know its not an IH tractor but..
Posted by george md on October 29, 2005 at 15:13:48 from (165.247.85.153):
In Reply to: I know its not an IH tractor but.. posted by Karl Hamson on October 29, 2005 at 10:30:57:
Karl,
Sounds like you should look for a worn exhaust
lobe , will idle great but doesn"t open the valve
far enough at higher RPM . Not opening the valve
enough keeps some exhaust gasses in the cyl, &
when intake valve opens the remaining pressure
goes back into the intake manifold causing engine
to pop up thru carb .
george
Post a Followup
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
