Re: diesel fuel treatment
Posted by El Toro on October 31, 2005 at 03:48:29 from (152.163.101.13):
In Reply to: Re: diesel fuel treatment posted by Hugh MacKay on October 31, 2005 at 00:43:32:
They used a mini-boiler that heated the coolant and the oil pans were shrouded with sheet metal to deflect the exhaust around the pans. This one vehicle had twin engines. I think 5 minutes was all the time needed for preheat. Hal
Post a Followup
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
