Re: diesel fuel treatment
Posted by Hugh MacKay on October 31, 2005 at 00:43:32 from (216.208.58.177):
In Reply to: Re: diesel fuel treatment posted by El Toro on October 30, 2005 at 15:42:26:
Hal: I've only experienced -40 temps twice in my life, once in 1956 and second time in 1996. In 96 I discovered the block heater on my 6.2 Chevy was not working. Engine was clean of any leaks. I filled a 12" cast iron fry pan with charcoal from barbeque ignited the charcoal and when flame died down placed it under oil pan of 6.2 diesel. 15 min later it was a summer like start. Maybe not as much technology as the Soviets, yet it was a preheat.
Post a Followup
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
