Re: 49 Farmall H RefusesTo Start
Posted by RustyFarmall on November 01, 2005 at 18:18:24 from (207.32.13.203):
In Reply to: 49 Farmall H RefusesTo Start posted by Flatland Farmall on November 01, 2005 at 17:43:56:
Turned the key? You need to make a jumper wire with an alligator clip on each end, connect one end directly to the hot post on the battery, and connect the other end to your coil, bypassing the resistor. This will eliminate any possibilities of a faulty wire or defective resistor. If it starts, don't run it more than a few minutes without a resistor in the system.
Post a Followup
