Re: 49 Farmall H RefusesTo Start
Posted by El Toro on November 02, 2005 at 04:07:31 from (64.12.117.13):
In Reply to: Re: 49 Farmall H RefusesTo Start posted by Flatland Farmall on November 01, 2005 at 19:02:09:
That's right, if that's a key start it sounds like you already have voltage at the switch since the engine will crank. There should be a wire
from that switch to your ignition. Find that wire and check for voltage with the switch in the on position. Check at the switch for 12 volts and keep following the wire to the ignition. There should be 12 volts at the ballast resistor
on the input side and 6 volts to the ignition.
If there's 12 volts going to the ignition it may have fried your coil. Hal
Post a Followup
