Re: 574 clutch
Posted by the tractor vet on November 02, 2005 at 11:43:27 from (4.124.73.104):
In Reply to: 574 clutch posted by JOhn Hobby on November 02, 2005 at 10:52:25:
You can adjust the free travel only and if ya got around and inch of it then that is all you can do and if it is still slipping then it is time to split her and replace the clutch pressure plate and throw out bearing and GRIND the flywhell and recut the step to correct hight . Oh and don't forget the pilot bearing.
Post a Followup
