Re: 574 clutch
Posted by JB2 on November 02, 2005 at 14:19:27 from (72.56.121.128):
In Reply to: 574 clutch posted by JOhn Hobby on November 02, 2005 at 10:52:25:
Hi John, if the clutch pedal has 1/2 to 1" free travel then it is adjusted correctly. My experience with 454,495 & 684 when it starts slipping in 3rd or 4th High it is time to consider a clutch, pressure plate, bearings replacement and maybe turning the flywheel. Also if it slips to much you could damage the facing on the flywheel.
My 2 cents
JB2
Post a Followup
