Re: 574 block heater
Posted by JB2 on November 04, 2005 at 20:26:42 from (72.56.121.128):
In Reply to: 574 block heater posted by gary54 on November 04, 2005 at 16:45:30:
Hi Gary, buy a recirculating heater that uses standard car heater hose. There is a pipe plug to remove on the left side of the block above the injection pump and there is another pipe plug in the front of the water jacket on the right side.
Drain about 1/2 the coolant out of the engine. Remove these two pipe plugs and replace with a pipe nipple. Mount the recirculating heater on the left side of the engine with a fabricated bracket. The bottom of the recirculating heater must be below the hole on the left side of the block. Using heater hose, connect the bottom connection of the recirculating heater to the nipple on the left side of the block and the top to the nipple on the water jacket. Theory is hot water rises and cold falls to bottom. Even in really cold weather 30 minutes to an hour is good to start.
Hope this helps
JB2
Post a Followup
