Re: H pops out of fifth
Posted by Haas on November 05, 2005 at 04:02:31 from (12.65.42.122):
In Reply to: H pops out of fifth posted by Mixman on November 03, 2005 at 14:39:29:
I have a Super H, torn down for this very problem. Most likely your 4th/5th slider gear, and maybe other problems as well. You are probably looking at a fairly complete transmission tear down and overhaul. On mine, in addition to the 4th/5th speed sliding gear, the bearings on the input shaft are shot and the main shaft bearing at the rear of the top shaft could probably be used, but has some play and I am replacing it along with the pinion bearing as well.
Post a Followup
