Re: Is Anyone Adding ACETONE to their fuel????????
Posted by Dale in Ar. on November 05, 2005 at 11:16:46 from (166.102.26.19):
In Reply to: Re: Is Anyone Adding ACETONE to their fuel???????? posted by VETTE on November 05, 2005 at 07:16:05:
how much are you adding to the fuel?? I've heard that you add 1-2 oz. to 10 gal.,is this about right or do you add more than that???Also do you use it every tank full or every other tank full ???
Post a Followup
