Re: Farmall 200 -Wiring harness/fuse block
Posted by Hugh MacKay on November 06, 2005 at 14:27:20 from (209.226.106.116):
In Reply to: Farmall 200 -Wiring harness/fuse block posted by Joseph Sullivan on November 05, 2005 at 13:58:26:
Joseph: You mention fuse block, as though there in maybe more than one fuse. There is only one fuse on Farmalls of that era and that is for lights. The ignition is not fused at any point. The wire from the coil goes directly to the ignition switch. It sounds as though you may have modified wiring. All wiring terminals at dash of a 200 are quite easy to see and work on once battery has been removed. You shouldn't need to remove any switches or the one fuse holder, unless they are defective and need replacing.
Post a Followup
