Re: How do I split my tractor
Posted by JB2 on November 07, 2005 at 19:20:27 from (72.56.121.128):
In Reply to: How do I split my tractor posted by Eamonn on November 07, 2005 at 13:26:46:
Hi Eamonn, you sure you got all the bolts out? There are usually 2 hidden under the battery box. Then there are usually 4 guide pins, 1 on each side and 2 at the top. These guide pins fit snuggly and can be stuck in the holes. The other thing that can keep it from coming apart is if one of the clutches have worn a grove in the spline shaft. This requires removing the bolts that hold the pressure plate to the flywheel so the clutches stay with the transmission half. The bolts can be accessed thru the inspection hole at the bottom of the bellhowsing. Hope you have the tractor well supported, be sure to wedge a block of wood on each side of the front axle between the axle and the bumper stop to keep the enginge part from rotating when it separates from the transmission part. Another trick I have used to separate the 2 halves is to let both supporting jacks down by 1/4" to 1/2" and this will cause the bellhowsing to separate from the engine block at the bottom, now wedge 2 flat bladed screw drivers in the crack, one on each side of the tractor, then raise the jacks by 1/2" to 1" until a crack appears at the top of the bell howsing, then wedge 2 more screw drivers at the top and lower the jacks again until the gap widens at the bottom. Repeat the procedure until the 2 halves clear the guide pins. If you have a floor jack under the engine part and once the guide pins are clear and with the rear wheels blocked, you can usually roll on the front wheels and the engine part will roll away from rear end. BE CAREFULL NOT to lower or raise the 2 halves to far off center as their is a great stress applied to casting around the guide pins. Do not want to crack casting. BE VERY CAREFULL make sure you have a secondary means of supporting the tractor halves if one of the jacks do slip. We usually make a support out of 4x4s. Good Luck JB2
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
