Re: RE: 434 IH Starting
Posted by JB2 on November 08, 2005 at 17:09:48 from (72.56.121.128):
In Reply to: Re: RE: 434 IH Starting posted by AL Sproule on November 08, 2005 at 15:53:36:
Hi Al, is this a gas or Diesel 434? If it is a Diesel then it probably only has the start switch connected to the S terminal. I have seen the other terminal used on a gas engine to supply 12V to the ignition system for starting and then when the key is release from start to run the ignition system is fed thru a dropping resistor. Does this tractor have a safety switch on the clutch? The 434 that we owned did not but it was an early 434, I know the 384 we had had a starter safety switch on the clutch. The clutch had to be depressed before the starter would engage. This switch caused a lot of problems and most farmers eliminated this safety device. Now to trouble shoot your start problem with a jumper cable. BEFORE ATTEMPTING THIS MAKE SURE TRACTOR IS IN NEUTRAL AND REAR BRAKES ARE LOCKED ON AND FUEL CONTROL ROD IS IN THE OFF POSITION. Test 1: Now take a single jumper cable and connect one end to the big terminal on the starter solenoid that has the cable from the battery (top terminal), now monentary touch the other end of the jumper cable to the bottom big terminal that is connected to the starter motor, the starter motor should spin but not engage into the ring gear. If it does not spin then there is the following possibilities: 1)Bad connection to battery or battery to ground. 2)Bad starter or starter to ground connection. As I rememember the ground connection to these starters was thru the front end bearing which was not good and later models had a separate ground strap from bottom terminal at the from end of starter to engine block. If test 1 works then test 2 is same connection as test 1 but this time monentaryly touch the jumper cable to the S terminal on the solenoid. This time the starter motor should spin and engage in the ring gear. If the starter motor does not spin and engage the ring gear then either the solenoid is bad or the ground on the solenoid is bad. If test 1 and 2 work then the problem is farther back in the start switch circuit or safety switch or fuse in the start switch line. Hope this helps JB2
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
