Re: Farmall A wiring questions - Still not chargin
Posted by El Toro on November 12, 2005 at 03:52:26 from (64.12.117.13):
In Reply to: Farmall A wiring questions - Still not charging. posted by Mark in WV on November 11, 2005 at 19:52:27:
You need to check your battery with a volt meter
to see what the charging voltage is. With 1/2 to 3/4 throttle the voltage should read 7 to 7.25 volts. If this voltage is near this, your battery may be the problem. You should check the cells with a hydromometer to mearsure the elecrolyte in each cell and compare the readings.
Each cell reading should be close to one another.
Hal
Post a Followup
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
