Re: This question is electrical !
Posted by John T on November 13, 2005 at 15:54:42 from (66.244.90.98):
In Reply to: Re: This question is electrical ! posted by Randy-IA on November 13, 2005 at 07:41:05:
Randy, I just got home and it look like Old has ya covered. When I use a 3 wire GM SI 10 Alternator like a one wire, I excite the lil No 1 side terminal via a wire from the ignition switches IGN (hot when ON) with a 10 ohm current limiting protection resistor and a 5 amp 50 PIV diode if necessary to prevent back feeding the coil in case she still wants to run with the igniiton OFF. The lil side No 2 terminal jumps to the big main rear output stud. The big main output wires with 10 Gauge wire up to the ammeters Load (NOT to battery/starter) terminal to charge the battery.
If shes NOT wired equivalent to how I said and its a GM 10SI, wire it that way n see what happens. The lil jump wire from the lil side No 2 terminal up to the main output stud serves as a sensor. If the battery is good she ought to full charge a bit after startign but then back off or else you may overcharge n boil over n outgas the battery !!!!!!!!!!
Let me know
John T
Post a Followup
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
