Re: Hyd Leak
Posted by scotty on November 15, 2005 at 06:06:00 from (199.231.49.128):
In Reply to: Hyd Leak posted by Florida Tom on November 14, 2005 at 19:30:43:
Hi Tom,
I have a Super A, not a Cub, but the units have a similar setup other than the Cub only has one piston I believe. If you are getting a leak from the bottom of the unit, you will need to remove the touch control unit from the tractor, remove the bottom plate and install a new gasket. Not a difficult job, other than draining the system. Hope this helps.
scotty
Post a Followup
