Farmall Tractors Discussion Board
Re: Re: Re: Re: DT466 from a cabover.. what (Besides a Zetor) will it fit?
Posted by RickB. on December 30, 1999 at 15:17:40 from (205.231.28.165):
In Reply to: Re: Re: Re: DT466 from a cabover.. what (Besides a Zetor) will it fit? posted by RickB. on December 30, 1999 at 14:41:57:
Some more thoughts: I'm not sure about the front cover & plate issue, it may bolt right up, something to check. Combine applications use a different timing cover than Ag tractors, I don't know where trucks fit in for sure. Front-sump oilpans probably will interfere with tractor front bolsters, original pickup tubes & screens from 414's and 436's won't feed a 466 oilpump enough unless they already have been converted to high-flow pumps. Combine applications for DT series engines include late 715,815,915 ; all 14xx and early 16xx. Of course boosting HP can bring powertrain and cooling system issues yadda yadda yadda. SDman can help here, too.
Post A Followup
: Re: Re: Re: Re: Re: DT466 from a cabover.. what (Besides a Zetor) will it fit?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
