Re: Confused
Posted by El Toro on November 16, 2005 at 04:21:04 from (64.12.117.13):
In Reply to: Confused posted by Kregg on November 15, 2005 at 20:37:19:
The Super A's prior to SN 310300 had the C113 block, tractors with SN 310300 to 356001 had the
C123 block with thicker sleeves and after SN 356001 they had the C123 engine with a water pump.
The C113 block you could use up to 3.125" sleeve and piston kit to make your engine with 123 cid.
The 123 block you can go up to 3.250" with an oversize kit.
Try weberstractorworks.com for a kit. You will need your SN. Hal
Post a Followup
