Re: Super C gear noise
Posted by CKIFF S on November 16, 2005 at 13:41:34 from (152.163.101.13):
In Reply to: Super C gear noise posted by Steve in FL on November 15, 2005 at 16:20:36:
Steve, Check in your filler hole with a flash lite from your clutch petal in the derection of your seat and look at your tranny gears, Espeicaly at the oil slinger at the farest to the back to see if theres any teeth missing,If so check the pinion bearing that is probley loose at the end of the shaft and cosed the problem,The BAD News is it means complete dissambly of the rear end to fix it, I just done mine last week and i also replaced the input shaft bearing. CLIFF S
Post a Followup
