Re: Hard starting I 340
Posted by captaink on November 17, 2005 at 06:57:26 from (66.115.214.56):
In Reply to: Re: Hard starting I 340 posted by doug in Wi on November 17, 2005 at 05:43:17:
I'm not sure if it is in the owners manual or not, but it would be in a shop manual for sure. To set the valve gap all you have to do is take off the valve cover. The valve gap is measured between the rocker arm and the valve stem when the piston in that cylinder is a top dead center on the compression cycle. (Take out the spark plugs, put your thumb over the spark plug hole and turn the engine slowly. When you feel air push past, put a piece of stiff wire in the hole and when it stops moving out, the piston is at top dead center.) There was some discussion on the board yesterday about what temperature the engine should be to set valves. My opinion is if the shop manual says hot, then it should be done after the engine is thoroughly warmed up and done with it as close to operating temp as possible. If the spec says warm, then set them with the engine at some comfortable temp above freezing. Hope this helps.
Home
| Forums
Today's Featured Article -
Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
