Re: 786 vs. 886
Posted by caseyc on November 18, 2005 at 06:20:34 from (66.17.100.10):
In Reply to: 786 vs. 886 posted by Mike in Vt on November 18, 2005 at 05:59:21:
i would go with the 886 myself. did the 786's have a full cab? all the ones i've seen only had the 4 post rops. a 986 or 1086 would be easier to find. a 986 would have the 436, alittle cheaper and easier to find parts for. the 886 would have a 360 (early one) or the 358 german (late one). both good motors but a tad on the expensive side to fix and alittle tuffer to find parts for. i'm not sure what the 786's had for engines. i guess in the end i would try for a nice 986. expect to pay anywhere from 7-10k for a nice one, that goes for all three, 786, 886, and 986. a 786 may be had cheaper but that's what the few i've seen go for.
casey in SD
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
