Re: 786 vs. 886
Posted by Nat on November 18, 2005 at 06:30:33 from (64.80.108.52):
In Reply to: Re: 786 vs. 886 posted by caseyc on November 18, 2005 at 06:20:34:
The 786 didn't even have a ROPS.
I believe the 786 was only made in 1980 and/or 1981, and it actually REPLACED the 886 in the lineup. I'm also pretty sure it has the shifter on the right-hand side like the 3088. This is a much improved arrangement over the clumsy left-hand shift of the other '86 series tractors.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
